It would make sense that GM used the same bucket frame since I have heard the Camaro seats are a bolt in but I would want to verify the dimensions and also that the hinge mechanism is the same and covers the same area of the seat exactly as a Cutlass seat.
Also the foam could be F body specific so it might not have a recess to mount the upper "pull in" on the back cushion which would be hog ringed to the rear of the frame or foam support bar, the lower one on the back and the seat bottom one appear to be in the same location but you could end with the upper part sticking out if unused.
You could also obviously attempt to modify the foam to work if there is no recess.
