'83 Cutlass Cruiser Build Thread
Been debating adding the vinyl woodgrain trim around the car once it's painted. Should I do it?
  • Yes, that wagon needs woodgrain
    Votes: 12 35.3%
  • No, leave that wagon smooth and simple.
    Votes: 22 64.7%
  • Total voters
    34
  • Poll closed .
Blake442
6,864
1,997
Minneapolis
Alright, time to get caught up! Not as many pictures as I would've liked, but you'll get the idea...
Looks like I left off with fixing the header panel and then a couple woodgrain teasers...
In the preview shot I posted earlier you can see the masking tape perimeter that I laid out as a guide.
All in all, the application of the woodgrain went exactly as I had anticipated it would... good and bad...
I started with the doors since they were flat to get the hang of working with the material, and they went pretty smoothly.
As I figured, the vinyl didn't like being wrapped around the edges, and lifted... I ended up trimming them flush.
I trimmed around the door handle opening (poorly) instead of trying to lay the vinyl in the recessed portion.
This would have been painted a similar brown/tan to the woodgrain at the factory, to avoid the glaring green poking thru like mine.
But there was no way I was going to paint the handle (and gas door) openings ****ing tan on my nice green paint!
Besides, this way I can still go back to all-green at any time...
The fenders and 1/4 panels were a little bit more work thanks to the wheel openings...
I did the passenger side 1/4 first, and it actually went pretty smoothly.
The passenger fender I got half-way thru and the vinyl tore, had to peel it off and start over.
The drivers side 1/4 vinyl tore in a small spot as I was peeling off the backing. I was going to give it a try anyways and then one side slipped out of my hand and about half of the 6 foot long piece hit the floor sticky side down... crumple it up and start over...
Finally the drivers fender went on incident-free, though it still didn't want to cooperate.
Over the course of August and September when I didn't update much, I was mostly taking care of all the small bits and tons of hardware.
Among those parts were my wheel well moldings that were in less than good shape.
Not wanting to strip the anodizing, I took the lazy route and just tapped out the dings the best I could. I can always make them nicer later...
With the vinyl in place, I then installed the moldings to help anchor the material around the wheel openings.
I was now also able to install the rear license plate pocket, door handles and lock cylinders, door mirrors and fender emblems.
The last piece of the puzzle was the 1/2" brushed aluminum pin-stripe tape around the border.
I managed to make it photograph ok, but I'm not happy with how it turned out and I'll be re-doing it in the spring with plan-B...
The material is just too thin and it shows the jagged and poorly cut edge of the woodgrain thru it... when it's not lifting...
It doesn't really like sticking to the woodgrain, but the paint is ok, and it absolutely does not like to do any curves whatsoever...
To top that off, the woodgrain also decided to start lifting around the wheel arches... I smush it back down and a few days later it's back up.
I think that if I had been able to let the car sit in the hot sun for a few hours once it was finished, I wouldn't have the lifting issues, but when I did it in mid October, it was just too late in the year for that kind of warmth... I'm pretty confident it will play nice with the right amount of heat...
Now with all the exterior wrapped up, I was finally able to put all 5 door panels back on.
Last summer when I impulse bought that Regal sedan, it came with an extra pair of rear doors...
They were about 95% junk, but I was able to score an intact pair of moisture barriers! Perfect since my originals crumbled...
I'll have to take some better pictures of the interior, but it looks pretty much the same as it did before... but now it's 100% complete!
Ok, time for a break, and I'll get the next part up...
Reactions: 7 users
7,987
18,693
Looks great Blake! Thanks for the update! I've been looking for it for a long time. Would using a heat gun help lock down the vinyl?
liquidh8
Awesome! Glad you were able to post some updates. Looking good!
12,174
9,776
Yeah, it's about time we saw some new updates...:p All kidding aside, it looks great. I was wondering what you used to border the woodgrain.
Like Jared mentioned, would a heat gun help in laying down the vinyl?
Blake442
6,864
1,997
Minneapolis
Thanks guys!
I used what I thought was a lot of heat...
If you hit it too hard with the heat gun, it starts to mess up the vinyl.
You can see in one of the shots where the area around the passenger front door handle is all shiney.
I hammered on this spot with the heat gun to see if I could get it to lay down in the curvature of the panel... It didn't work lol
Like I said, I think the sun will be the best helper once the weather allows it...
More to come...
Blake442
6,864
1,997
Minneapolis
Next I turned my attention to the engine compartment.
I mentioned before that my plastic wheel well tubs were in not that great of shape thanks to the Texas climate...
I was apprehensive at first about spraying them, but figured I'd give it a go...
And I probably should have, but instead I just used Mother's Back to Black.
Honestly they turned out pretty good considering all it took was some elbow grease... and I can always hit them again if need be.
Since the fender emblems were finally in place, I was able to install the wheel tubs along with all the pieces that mount on top of them.
Complete except for the wiper motor and arms.
I also finally got a starter and installed it, and I changed the oil and filter while I was down there...
A year or two ago I showed off among my junkyard scores a pair of radiator opening seals that I managed to find intact.
Well after some searching online, I came across the almost correct material (a little thicker) and set about making new pieces.
These pieces run along side, then across the top of the front side of the core support, acting as a shroud to help direct more air to the radiator.
You can see how they tuck into place to direct the air...
Pretty slick. They help hide some of the ugly, and along with my 7-blade fan and new clutch, should keep everything cool...
I had enough material for two sets, and promised the extras to Jim... (Totally forgot to send those out!)
HAFROD, if you want some too I can send you the patterns... You two are the only guys I know that could use them!
I had already put the headlite buckets and bezels together after I buffed the header panel, but the icing on the cake was the grills!
I got these beauty's from Ben and repainted the silver insert. These cleaned up really nice, so I'm pleased as punch!
Still need to put a little black on the flat spots on each corner, but that can wait...
Now all I need to do is either restore my header panel emblem, or luck out and find a nice one! I've been hoping for a nice one...
Blake442
6,864
1,997
Minneapolis
And at last, the moment of truth!
After sitting for two and a half years, a little gas down the carb and a few quarts of ATF, it drove out of the shop under it's own power!
No more hail dents here!!!
Oldsmobile emblem is NOS. The rocket emblem is original, I just cleaned it up and re-did the red.
Fender emblems were cleaned up, sprayed semi-gloss black, and then wet sanded the face of the letters until the chrome came back...
I forgot to get a picture of it loaded up on the trailer, but the car is back at the house just a few weeks past the 3 year anniversary of starting to take the car apart...
I'll take care of the front bumper over the winter, and will re-do the brakes in the spring, along with fixing the issues with the woodgrain.
Other than that, it's just a pair of front tires and a wheel alignment away from some cruising! :banana: :wax:
All tucked in for winter... I'm gonna enjoy the break from not going out to work on the dang car 3 days a week and stay home and play with my model cars!
Thanks for all the kind words guys!
This project has been a lot of fun for me, and I'm glad you guys have enjoyed following along!
Stay warm!
Reactions: 13 users
kalidromos13
363
435
Palmdale, CA
Blake442, what material did you use to make those radiator closeout panels? Would you mind sending me the patterns as well, it would help me out with an idea i have. Awesome build by the way! Lots of valuable information in this thread.
12,174
9,776
Thanks for keeping us up to date, Blake. It's nice seeing the car resting comfortably back in your own garage.
I'm assuming the front end will settle a bit after the bumper is back on?
Btw, nice pics.
