BUILD THREAD “The Juggernaut”
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
With my anal-retentive tendencies, I wasn't satisfied with the look of the two unused holes hanging off the end of the arm past where the linkage mounted.
After some quick checking of clearances on the driver's side rear location, I found that the driver's side arm would have to be shortened for sure to avoid contact with the air and rear brake lines on that side anyways. So both rear sensor arms came off, and got cut down, shortened, and smoothed out to a clean radius that closely matched factory:
As with most modifications, once the first side is figured out, the second side is usually a lot quicker and simpler. And so it was on the driver's side, with the exception of one little hiccup...
Rather than drilling through holes and bolting on the sensors with the supplied machine screws and nuts, I wanted to be able to mount them with just the machine screws. So I had been drilling and tapping the holes as I went along. Well, as luck would have it, the tap I was using snapped off almost perfectly flush with both sides of the frame on the very last hole. :mad:
After much cursing and fighting with it for a bit, I decided to cut my losses for the night and shut things down. I've been doing this long enough now, that I realize sometimes it's better to walk away from things for a bit and go back another time and tackle the problem with a clear mind rather than continuing beating a dead horse.
This mentality paid off when the next night after some contemplation I realized (through more good luck than good planning) that my rear firewall side panels were still removable providing near perfect access to the busted tap and sensor location.
With that firewall panel removed, I was rewarded with just that. A couple good whacks with a decent sized BFH and a sharp punch broke up the broken chunk of tap and it fell out. I cleaned up the offending hole, and ran a new tap through the hole to ensure the threads were good, and bolted up the sensor. Problem solved!
In this next pic, you can see the proximity of the arm to the air and brake lines, and the necessity to shorten up the arm:
Now that the sensors and their associated components were installed, the last things to be done were to shorten up the wiring that goes to them and plug them in.
I'll spare you the enthralling details of shortening, crimping, heat shrinking, etc on the wiring, and just skip to the completed pic:
So that's pretty much it. Obviously the driver's side wiring was similarly shortened and routed, and that concludes the rear sensor install. Believe it or not, these were probably the easier of the 4 sensors to install, not much to take into account due to the simple "up or down" movement of the rear suspension.
The fronts however, may prove to be much more challenging. Less available real estate to mount things, harder to hide or at least make it look "purdy", and more components and moving parts to take into account and avoid.
That task will be the next one to take on, wish me luck and tune back soon to see how I fare with that...
Thanks for checking in everyone!
D.
Rktpwrd
4,166
23,915
Bout time Donovan, it's freakin 5 on the east coast ya know.....guys been waitin and all that! Now it's dinner and the wife is callin.
Just a little extra effort ok, all I'm asking for here.....
Sorry 'bout that Rick!
Local World of Wheels show was here yesterday which ate up all of yesterday, (and not one G body present in the show, G body representation here SUCKS!!), and these updates take me a while to compose and present in a manner that makes sense. :(
Dinner will wait, tell her you have more pressing things to attend to first!
;):rofl:
Opie Knievel
Sep 6, 2010
1,512
1,859
Brodhead, Kentucky
On a similar note, I'm gonna ask that you release your updates on a schedule, like a magazine or something. That way I know when to expect it. I was out in the garage trying to get some stuff done and then I saw you has posted an update. Well, that distracted me for a few. I didn't want to get behind on your thread again. So, if you don't care, PM me and I'll set up a schedule for you! Lol :rofl:
Seriously though, I like the sensor install. Everything on your car is so clean and neat. I envy that. I know I don't have the patience to do that though so I don't try. Lol.
I hate when a tap breaks!! Glad to see you didn't have a lot of trouble getting it out.
When are you planning on tackling the front? Do you already have a plan of how you'll do it?
I'm hoping you'll do a video when you get them all installed showing how it works.
Great work as always Donovan.
Rktpwrd
4,166
23,915
Schedule, huh?
I'm not sure I'd bank on that happening, but I am trying to keep y'all updated as best I can!
Lol
Thanks for the encouragement and kind words Opie. 'Precitate it my friend, thank you!
Tonight I'm going to test fit and play around with options to buy clearance on the E-brake bracket to frame, as well as clean up the little bit of surface rust that's accumulated on the framerail in the wheel well. That needs to be addressed so that the rear wheels can go back on.
I also want to formulate a plan to add bumpstops back to the axel without sacrificing a lower stance. In this instance, every 1/16" counts! I won't accept any metal to metal contact, it'll sit on the bumpstops, but I may have to recess them so as not to increase the height when it's lowered. Not sure how that's gonna play out just yet.
I should be able to start on the front sensors install by tomorrow night. I've already had a preliminary look at the fronts, and may be developing a plan of attack, but I really want to explore all possible options and find the best possible location for them before I commit to anything.
It may not be on a fixed schedule, but I assure you the updates will continue to come, and I'll be keeping everyone in "the loop". You'll just have to keep tuning back in to see how I make out. Think of it like Christmas morning, you never know what (or when!) you'll get!
D.
Opie Knievel
Sep 6, 2010
1,512
1,859
Brodhead, Kentucky
I should have know better..... Lol
Donovan, you're a maverick. Mavericks don't adhere to anyone's schedule but their own! Lol
Rktpwrd
4,166
23,915
I've been called a lot of things over the years (and not all of them flattering, lol) but maverick? I think that's a new one on me...
Maverick doesn't sound so bad, I think I can live with that one!
Thanks brother!
liquidh8
Looks great Donovan, looking forward to the next update, as always, very well thought out and a clean install!
oldsofb
1,384
4,014
Maryland
Glad the board of inquiry cleared you of responsibility for Goose's death. Tough luck though.
Mav, the simple fact is you feel responsible for Goose and you have a confidence problem. Now I'm not gonna sit here and blow sunshine up your *ss. A good mechanic is compelled to evaluate what's happened, so he can apply what he's learned. Up there, we gotta push it. That's our job. It's your option, Maverick. All yours. :D
Hutch
Rktpwrd
4,166
23,915
Thanks Jim.
As you know, it's the forethought and planning for all the possible contingencies that make or break a successful install. I always try to think as far ahead as I can and plan for every and all possibilities. Most of the time it works out, but sometimes it's unavoidable, as evidenced by my having to move the one bulkhead connector.
I'm just glad I didn't have the fuel lines to those connectors bent and plumbed in already!
Hutch
Wow, someone has seen that movie a few too many times me thinks!
Well done Hutch, I never would have made the "Maverick" association to "Top Gun" before you posted it! Made me laugh, anyways!
Up next, my "maverick" solution to the E-brake bracket interference issue...
(Sorry, couldn't resist!)
:rofl:
D.
