20,391
took the horn off my quadrajet, the car was running great but I could not get the fuel mixture right, it was close but it fluctuated. It turned out to be something I did when I removed the main rods last time,I bent one of the arms holding the main rods so one road was sitting higher in the jet. It's something I usually check but I forgot....thanks to Jack's suggestion of lipseal on the horn gasket is working great but the cherry fragrance is gone....:)
19,992
Pulled it out of the garage to straighten out some of the winter mess / hording.
Found a pic in my toolbox......proof I use to run a Q-jet!!!!!!!
Also found out my parts washer is leaking :(
7,987
18,693
I think you need a bigger toolbox there hoss!
7,987
18,693
Finished my front inner fender beatification project. The tops are painted with Krylon Fusion satin black as mentioned before. The bottoms my brother sprayed with 3m undercoating. A lot of sand scratch on both. I went crazy with 400 on the second one but it's about the same as the first. That plastic just doesnt sand that great. They will look good on the car. I just need to put the magnifying glass away. Also cleaned up the little bracket that fastens the accumulator to the a/c case. I like how it looks natural. I think I will find some low gloss clear to spray it with.
19,992
7,987
18,693
I actually need another one I'm out of room.
I know the feeling brother, though I don't have near as much storage as you.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
Heard that!!!! I'm very limited on space at the house the wife and i are renting. I have 2 toolbags here, a decent channellock toolset in case that has been a life saver many times over, and a toolbag in my trunk for yard trips. Most of my better tools are at my brother n laws garage in a 6 or 7 drawer tool chest.
20,391
my friend who owns the recycling yard has a son who had the 60's Dart thermostat housing I was looking for so I picked it up today.....:)
7,987
18,693
I sprayed my accumulator bracket with Rustoleum satin clear enamel for a 'natural' appearance and am well pleased with the results.
