Ive been working 80 hr weeks and I tell ya the best thing about being up at 2 in the morning is getting to read the new posts during my first 4 hours at work lol
Sounds like you're enjoying following along with the updates! Glad to hear it.
Continue to tune in occasionally, and follow along as I progress. Hopefully it'll continue to be (somewhat) entertaining and Gasp! even educational!
Lol
Thanks for the kind words.
Awesome b progress! It looks great Donovan.
I too prefer to sand, grind, or cut out rust.
Sent from my Z981 using Tapatalk
Thanks Jim.
Sometimes it's safer to stay with what you know. I know that if I physically grind it out, there's no chance of it returning. It's more piece of mind in my opinion over using a manufacturers chemical treatment product.
Fantastic work Donovan. I really enjoyed reading the update. I take it there was zero distortion from the welding?
Haha
I knew you were going to ask that!
Correct. As you predicted, there was virtually no distortion from the welding process. In fact, there was more distortion simply due to the fact of having that thin layer of panel bond in between the pieces and the Cleco clamps.
If anything, the entire repair is now slightly low, which I consider a good thing. I'd rather have it a bit low than high, it's easier to hammer and dolly and add more filler if needed than it would be to try and shrink the whole area to bring it back down.
Thanks for acknowledging the hours and effort that goes into composing these updates. I know you can relate with the threads you have on your dad's Galaxie, and Sean's Camaro.
Cheers my friend!
Thank you! Appreciate it!
Awesome work Donovan! Thanks again for staying up late and spending so much time on the update!
No problem Kevin, my pleasure.
If those that take the time to read through and follow along can gain tips, tricks, or even simply the confidence to tackle a seemingly daunting task like this, then I consider all my time and effort in posting the progress worthwhile.
After all, I have to do it anyways, why not share my knowledge and experiences with everyone along the way?
Hi, Donovan,
Beautiful work. I've been wondering why there's been no noticeable grinding pattern on the roof where the paint has been removed up until now that you've hit it with the 8" 40 grit disc. Am I right to understand that you used an 80 grit on a D/A sander to produce that almost-smooth finish? How long has it been since the paint was removed? Were the spider-track rust spots visible then, or have they shown up in the interim?
I, too, look forward with great anticipation, and bated breath, your next installment! Don't keep us waiting!
Cheers - Gary
Hi Gary. Thanks for commenting on the thread. It's nice to have you.
I actually mentioned my reasons for sanding off the old paint first rather than grinding earlier on at the start of this undertaking. It's so that I can safely determine the extent of the damaged areas, and "sneak up" on the perimeters of the rusted areas. The paint all has to come off for the repair anyways, so this just makes sense to me.
The other reason for doing so, is that our cars are painted with a lacquer based paint. When you attempt to grind the paint off, I find it just smears with the heat and speed of the grinder. Sanding it off with 80 grit on the DA doesn't do this. It simply removes the paint, and reveals whatever is hiding beneath.
Which brings us to your next couple questions:
Yes, the smooth finish you saw in the pics was the resulting finish left by the 80 grit on the DA.
I've been posting these updates in as near "real-time" as I can, so the paint has only been removed for the last week or so.
The spider-tracking traces of rust actually weren't visible at first, before sanding. They revealed themselves as I sanded the top layers of paint and primer off. Another benefit to sanding the finish off, rather than going straight to grinding. They were the start of rust pitting in the metal underneath. They've since been dealt with, they are no more!
Excellent questions, hopefully I was able to answer them in a way that makes sense to you.
Thanks for contributing to the thread, you may have asked questions that others may have been wondering about.
Donovan
lookin good! I'm actually hoping to benefit from this writeup, as I was working on "Chief Sh**tting Bull" today, and noticed rot out on the leading glue edge of what's left of the vynil top.... I may not be able to do the steps you're doing, but it's given me insight on what to expect, and at least an idea of a plan of attack.
Darin
Thanks Darin.
Hopefully you don't find the same damage and to the same extent as I did, but like you say, at least you know what to possibly expect.
If you expect the worst, you'll either be validated, or pleasantly surprised!
Thanks for the kind words. I hope this documentation can indeed be of benefit to you!
Thanks everyone again, for all the great comments, likes, and support.
You guys are the best.
Donovan
