Crankcase breather rubber parts 1986 442 Vin9 307
Blues Pwr
6
Replacing the Crankcase Breather on Driver side Valve Cover
It looks as if the crankcase breather is at least 20 yrs old and all stock.
It has the driver side valve cover breather and it connects to a metal tube with a dog leg bend and it goes into the side approx. middle of the stock dual snorkel air cleaner housing.
Had to gently pry it out of valve cover rubber grommet that was hard and stiff/dried out.
I did manage to get it out.
When I tried to remove the rubber grommet/elbow that goes in to the upper hole of the crankcase breather, it is also dried out and brittle, I could not get it out to install it into the new breather.
I tried to spray WD-40 and pry it out with a small screw driver and it started to crack so I stopped before I ruined it and put the old breather back in.
The other the rubber grommet/elbow that connects the metal dog leg shaped tube to the air cleaner is very spongy and soft and needs to be replaced too.
I tried Pep Boys, Advance, and Auto Zone and they don't stock them.
I think Dorman Products used to have them but I can't locate what I need as most are sold by I.D. and thickness which I don't have the specs. for.
If anyone has a vendor and part #'s
1. Drivers side valve cover, crankcase breather rubber grommet
2. Rubber grommet/elbow that goes into top of crankcase breather to connect with metal tube
3. Rubber grommet/elbow that goes into the air cleaner unit and connects with the metal tube
Thanks for any and all help
somaphox
Jan 16, 2015
67
13
its alittle...ghetto to speak bluntly but get a normal sized grommet for the hole then insert a piece of tubing the size of the pcv valve.if you get really ocd with it you can make it sit almost flush.otherwise hit up a junkyard or ebay,but aside from those options...well possibly napa they have weird things others dont sometimes.
crap sorry reread your post and its about the crank case breather,in which case get a chrome edelbrock aftermarket breather with hose attachment then either fab from there or attach a peice of tubing to the end of the hose fitting that you can put the metal tube into.regardless im sure you can come up with something but best bet for oem stuff is he junkyard
8,823
7,775
Blues Pwr
6
Thanks so much for posting the links, I appreciate you taking the time, this is exactly what I was looking for. I'm getting some parts from there (Inline Tube Motor City Super Cars)
I'll come back and post, to let others know about fitment and part numbers and prices.
Also Thanks to Everyone who took the time to post a response.
8,823
7,775
I was missing the factory parts for 70 but decided against a completely stock look. So I knew who was selling what.
