V6 headers mounting question
Cutty1987
Aug 15, 2017
92
10
Do they take gaskets? My neighbor told me they dont because they were "laser cut" or something that it was straight fine it flushed with the block, is that true or do i need the gaskets?
I have the v6 3.8..
Also, does it matter what bolts go where? My daughter managed to unravel my bolts when they were taped and labeled driver and passenger side..
Thanks guys
Cutty1987
Aug 15, 2017
92
10
These are the bolts, some bigger than others, and some have extra nuts on them..
7,987
18,693
Are you replacing the manifolds with headers? Either way, use high quality gaskets. Headers often come with new bolts. The stock manifolds generally are thicker than the header flanges, so you need shorter bolts. I'm speaking generally since I'm not an expert on the 3.8.
7,987
18,693
The stock ones are exhaust manifolds. You definately need to use gaskets. I recommend using the copper gaskets UNGN referred to. On your stock bolts, it looks like you have three different lengths so it definately matters where they go. The bolts that are double ended studs are for bolting stuff like brackets to the engine at that location so it matters where they go. Hopefully another member with a stock N/A 3.8 can snap some pics for you to help you get it back together right.
Cutty1987
Aug 15, 2017
92
10
I hope so.. that would help out so much.. but ok sweet.. will get the gaskets later, it just trips me out because there was no gasket at all.. just both sides, bolted up..
7,987
18,693
I have heard of certain engines where there are no gaskets between the head and the exhaust manifold. I would not put it back together that way.
