There is no advantage to a 2nd Gen Camaro spindle. A stock g-body spindle/rotor/and caliper will be lighter than the f-body.
what is the difference in the weight?
This is a guess. Everything about the 2nd Gen f-body setup is bigger. Larger spindle, larger diameter rotor, larger caliper, larger pads. I would say for a conservative guesstimate, at least 8-10lb difference between 2nd Gen F-body and a G-body per side.
besides your guess on the weight why would you think there is no advantage of a larger rotor, larger caliper and larger pads, also with it being a taller spindle it also helps with camber. One other thing is the F body spindles give about a 1/2" wider track adding stability to the car and it keeps the tire more in line with the wider rear I have on my GP
