Wheel tire size for 87 cutlass
Kevin12
n00b
Sep 28, 2017
2
I just got an 87 cutlass supreme and want to put weld wheels on but having a hard time finding out what 15x10 rear backspace and tire size will work and 15x7 front tire size thanks for the help
UNGN
3,048
3,264
Southlake, TX
With a G-body you want between -6 and -12mm offset in back and -6 to zero offset in front with 15" wheels.
The 15X7's 235/60's is about as big as you wan to go. In back you'll probably need to roll the fender lip on a cutlass, but a 275/50 or 275/60 should fit on a 10" rim.
Qdub24
1,796
785
Columbus, GA
4.5" max backspacing without a frame notch
9,609
12,663
I personally think on a Cutlass which because of the shape of the wheel well is limited in tire size and even with a frame notch a 15" x 10" rear rim would be extremely tight and without a frame notch for it to have adequate clearance from the frame it would most likely stick out of the wheel well.
I also feel that a 275 series tire will be at or beyond it's rim width requirements and would be "stretched" to fit on a 10" rim.
Gozer442
281
259
Ontario, Canada
On my old '87 Cutlass, I had a set of offset aluminum slot rims with 15x10 on the rear....wrapped in 295/50/15 BFGs. The fender lip had to be rolled slightly, but it did have about an inch of space between the tire and the frame on both sides.
If I went with that size combo again, I'd notch the frame, and get the correct backspacing.
Kevin12
n00b
Sep 28, 2017
2
So you think an 8"rim on the back would be the best way to go? Whats the fattest tire I could get away with?
9,609
12,663
I personally like an 8" rim in the back of a Cutlass or any Gbody without a frame notch, it avoids a lot of headaches.
I am currently running a 275/60R15 on my Regal but I think because of your wheel well shape a 255/60R15 might be a better option since it is wide but shorter.
Let the Cutlass guys chime in for there opinion though on what backspace and tire size work best.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
FWIW, when I had my Centerline's on my 87 Cutlass I was running a 15x6 front, 15x8 rear with 4.5" BS in the rear. I only had a 235/60/15 and there might have been 7/16"-1/2" clearance to the frame. Ideally, a 4" BS on the rear sets the wheel even in and running a 255/60 would be no problem, 275 will fit with rolled wheel lips.
HTH
