Uhhh 4th AND overdrive? Did one switch just lock up the converter or is it gear splitting?
I believe he goes back to 2nd gear to start all over depending on speed. It's a bit unclear. Here you go... maybe this will help?This guy thinks TCC lock up is "overdrive".
I'm still confused at the end of the video where he shifts it with the shifter. What is the point of the switches if the shifter works?
Cheap enough. Wiring schematics?To be REALLY cool the should use this instead:
Shifter
Duct tape 3 together for a $45 "Lightning Rod" set up.
