GBotM Nov '17 - WIDE TIRES
GP403
Administrator
Site Admin
Feb 25, 2005
4,509
4,903
Rolla, MO
The wider the better. After last month I will ONLY take the first SEVEN entries that meet the criteria. What's that you ask?
  • Must have tires
  • Must have tires wider than 9" in the back. 9" does not count.
  • Need to include the tire size (width-%-R-radius) in your post.
  • Tires must be on wheels on your axle. A set of 20" side tires in the back of your El Camino or your trunk doesn't count :banana:
I figure the 9" limit will make it a little more interesting. Picture MUST be from the back 1/4 or full-on showing just how wide those things are. obviously we're going to see a lot of drag cars here, or maybe not. I dunno. Trying to make it interesting.
Will run the entries for 7 days or until we have seven qualifiers.
Oh sure... I cannot play again for a year. Wonder if I can finish building the MCSS in 7 days? ;)
  • Optimistic
-83MONTESS-
4,570
967
Bellevue, Ohio
My 87 Aerocoupe with 295/45 17 Mickey Thompson ET Street radials on 17x9" wheels.
Reactions: 9 users
Qdub24
1,796
785
Columbus, GA
'83 Cutlass with 275/60/15 rear tires
partsbox
160
305
Maryland
1987 El Camino with 10" wide BFG g-Force™ Sport COMP-2 255/50ZR16 tires on the rear and 9.6" wide BFG g-Force™ Sport COMP-2 245/50ZR16 tires on the front. All on 16x8 S-10 Xtreme wheels.
timo22
550
1,072
St. Louis,Mo
275/60-15's are at least 10" and maybe closer to 11". I have 245/60-15's and they are a little over 9" so I'm not big enough to play....timo22
oldsmobile joe
2,067
3,053
mpls
275/40/17 tires on trans am ws6 rims at all 4 corners.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
235/45/18 on late model Camaro rims. Supposed to be 9.3" section width. Room for more...
