You can use it all you want until it expires. It was worth $8.50 to me and that ate the shipping on a separate item. As stated- every little bit helps.
That coded worked for bonnewagon, you must be blacklisted.......
I never ordered from Rock Auto, how much discount do you get with a discount code? Could it be that Mike is in Canada the problem with the code not working?
