Car wont start after changing fuel filter
20,391
The spark test no little lightening strikes. ? So do i replace the coil next
start with the simple things, I posted before if you have no spark to check to make sure the wiring to the distributor is plugged in and if it is then check to make sure you have power on the pink wire with the key in the run position
19,992
Make sure there isn't a banana in the tailpipe!!
  • Creative
20,391
Here is a question I can't answer, if the IGN ECM and/or the ECM fuse is blown will that kill the distributor
img_0081-jpg.69914
84 W40
578
790
You would still have power to the distributor red or pink wire if that fuse was blown or pulled. The engine will run like if you disconnected the ecm harness on the distributor to set your base timing. Was the distributor cap replaced? If it was and the metal ground strap not put back on with the coil it will burn out the ignition module in 5 min and no spark. Could be a bad coil too.
img_0081-jpg.69914
20,391
Thanks, when it comes to the ECM I am the same as Sergeant Schultz, I know nothing...:)
