My almost blowout
Wageslave
1,749
3,338
I was driving home from work the other night and started to get a vibration from the back. It made it home 15 miles without issue, but had a flat in the morning. This is what it looked like.
I actually let the air out of the tire once I got it off of the car, since this thing is an explosion hazard. I
have not had particularly good luck with these tires, but I think a pothole may have got this one.
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
That just didnt happen overnight....
Guy
9,611
12,670
It looks like you were already way past due for a new tire(s) anyways.
Reactions: 8 users
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
Guy
And you were running them under inflated. A tire without enough air pressure in it will wear the outsides prematurely, while too much will wear it in the middle.
Time to pay a bit more attention to your tires IMO.
Wageslave
1,749
3,338
This tire actually got rotated from the front after I had some alignment issues fixed. That whole side got wore down a while back. That, and it tends to be the one that spins when it "One wheel peels." This tire was pretty well shot, but I do keep them right at 32psi.
DRIVEN
8,074
14,533
*CENSORED*
Glad you caught it before it cost you a quarter panel.
20,391
That tire was shot many miles ago.
