where to buy steel body mounts
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
12,174
9,776
Some years back someone sold aluminum body mounts. Other than being used on a strictly track car, I couldn't see them being used on the street. I think the ride would be much too harsh. It would probably jar your teeth loose,
20,391
when we raced G bodies the rules were no steel, we had to stick with rubber bushings so we used hockey pucks
12,174
9,776
Steve,
I have heard of hockey pucks being used, but never steel.
UNGN
3,048
3,264
Southlake, TX
I'm pretty sure my 2+2 got Hockey pucks, at least that is what I told the guy who was caging in and putting in the fuel cell cage.
I recommend that all contact between metal and plastic or plastic and plastic has something that dampens vibration in between, or the buzzing will drive you nuts. For years I would be tearing pieces of paper, folding them up and shoving them into gaps to dampen the noise.
melloelky
4,155
9,546
mass
if you do decide to run the solid mounts,use a stock style bushing @the radiator support or else your headlights won't last.
-83MONTESS-
4,570
967
Bellevue, Ohio
I used the aluminum ones from JT Racecraft on my 83. I didn't mind them at all. When it was totalled out and I started pulling parts I was too lazy to pull them so they went to the scrapper with the shell.
I think people over dramatize the solid bushing being too harsh thing. Same with engine mounts.
