Radiator electric fan combos??
454GrandPrix
429
818
Lehi, Utah
Do you have the wiring diagram you used to set this up with the Volvo relay?
I just wired it like the picture on the relay. The input power wire comes straight from the positive battery terminal with a 30amp inline fuse.
Did you use the BMW temp sensor that some have suggested or did you go another route?
When I was carbureted, I simply installed a toggle switch on the dash to send the (low power) ground signal to activate the relay and turn on the fans. Now that I have my FiTech system, I use its fan signal ground output to control the relay.
I know this has been beat to death, but I haven't found the post that mentioned Liland Global. Has anyone tried this: https://www.rockauto.com/en/moreinfo.php?pk=10332276&cc=1247071&jsn=590
My shizz is leaking, and I think it's the crimped seam at the plastic tank (can't find an actual leak-just coolant on the ground and in the trough of the core support).
9,609
12,663
19,992
They are here in NY. So I would stay clear of them!!!!!! :banana:
I was looking at their gas tanks for the Cutlass and passed on it.
They were a little cheaper than the Spectra, but I couldn't find any info on their products
eric_cspan
22
29
13
I'd be wary of that one. 2 rows but core thickness of only 1.77"? That means they are only using 2 rows of maybe .75" tubes.
eric_cspan
22
29
13
Understood. Just wanted to make sure it wasn't going in a big engine
