Fuel tank issue = I don't like it and need a solution
7,987
18,693
No idea how new or if it is bullshit.
I called them like 2-3 months ago just before I bought mine to ask them about it
Your's is in, isn't it? How does it fill?
19,992
not in yet
been to cold or raining or both so far
19,992
Its just hows i be
csstrux
143
76
I bought a doorman I THINK from Rock Auto. No issues. This is assuming the neck swap goes south.
mr84monte
32
25
Didn't try the neck swap, but ordered the doorman last night, and if that doesn't work then I'm going to switch to efi along with a new tank set up for FI.
jakes87SS
506
1,330
ohio
so im running the aeromotive gen 1 stealth system shes still not the best to fill but its better than my stock replacement spectra premium tank that barfs at me every 4 gallons lol. the aeromotive fills 3/4 of the way at normal speed then must be filled the last 1/4 as slow as can be and makes filling the tank from a qtr tank take about 8 minutes or so its not the end of the world but all my other cars can be done from nearly one in like 4 minutes or less. theweromotive doesn't barf back fuel it just takes its sweet time.
L92 OLDS
2,872
3,050
West Michigan
Do the neck swap! Swapping in a factory GM filler neck solves the issue. Don't bother with the goofy plumbing and added exterior vent lines. We should make this a sticky. I think I did this 7 years ago....
csstrux
143
76
I did get the one for a GN as an LS swap was in the works. Decided to go a different rout though. Best luck.
