If I ever get to PGH, I'll dance in the crosswalk for you.
Today works in the garage with dad...Covered lessons on levers, screws and material hardness/durometer, and why leverage is our friend.
It was in that moment that Tatiana realized just how much of an @$$hole her father really was when he made her run a wood screw into a piece of aluminum plate with a screwdriver...
...but changed her mind (slightly) when he showed her there was a better way.
Tomorrow she'll be working in a garage with her boyfriend. Time sure does fly
Fair enough...
Decided to put the rotors on my mom's car I meant to last week. Seeing how the digits on my left hand function again and fit under a glove, and it wasn't freezing *ss and snowing, I took a shot. Being a UP car, I expected a bit of a fight. It started with me wrestling the wheels off with my trusty 10# sledge. Next I had to jump right to the I wasn't asking bar to crack the caliper mount bolts loose. The rotor wasn't budging. You know what they say, if brute force isn't working, you're not using enough. Man, this rotor is exceptionally stubborn!
Doh!
I hit this guy on the back side with some PB blaster and he came right out. As did the rotor. Next, I unboxed the fresh AC Delco rotors.
Looks like I'm only doing the one side today. Got a replacement on the way from Amazon, but they usually slowboat replacement stuff. I need to clean out the center bores on the wheels better too so they slide over the hubs the way they're supposed to.
