9,167
15,344
For the horn, do you have two & where are they at? (Can't remember if you Monte is a factory SS or not.) SS cars have them in the drivers fender by the vapor canister, regular cars had the on the left & right header brackets. All Montes did come with two.
mclellan83
4,259
9,457
Pgh, PA
That's why I ask, I only see the one in the drivers side by the canister and my horn had worked but recently noticed that it didn't. So when we found that wire I was wondering if that was a second horn wire because it looked like the other side but already had one there didn't know there was two
9,167
15,344
I'm guessing that when the nose conversion was done only on wire was made to extend over to the fender. Fish it out to have both wires at the fender. Check for a bad splice for the horn to quit working.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Burd
248
233
Detroit
Traded some parts for a dealership car cover, I guess it covered the new cars in the showroom till they could show them.
it’s a F Body, G Body? 😂
  • Love
mclellan83
4,259
9,457
Pgh, PA
Forgot to say it is a real SS
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,809
Louisville, KY
Mounted a fire putter outer in the trunk. It's hidden by the block off panel, and there just in case. Also, car is outside and I'm still blown away how good the coil covers look...
Reactions: 14 users
CopperNick
3,357
3,018
Canada
My 85 SS has the two horns that have been described above. They are both attached to brackets that are bolted to the outside face of the rad cradle and would not tend to be visible with the S/S nose fascia and cover in place. The power wire is a dark green and power to the passenger side horn is a jumper wire in the same color that is attached to the wire that plugs into the driver side horn at the female plug in socket. A broken or never connected circuit wire is always a possibility. Could also be a broken contact in the steering wheel.
Haven't touched the rear end in my 85 as yet. Lungs are still giving me some grief and dust and damp do not help.
