1983 Oldsmobile Cutlass Supreme Sedan LS Turbo Build
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
Track will tell the true numbers, but it made 500+ whp, 600+ ft-lbs thru an unlocked TH400 and Ford 9” rear end IN SECOND GEAR 👀
Also made 18 dyno pulls and it didn't blink an eye :D
Fixed that for you....
Tony1968
2,313
5,099
NW Indiana
I don't get it...? Why would it be in 2nd gear?
And if it was I believe that scews the numbers obtained
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
With my 3.25 gear ratio, the top of third was going to be nearly 180 mph wheel speed
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
True true. Not sure how that helps or hurts lol
I believe Tony is right, I remember something about this in my hours of mindless youtubing.
Spongebob Squarepants GIF
Maybe you should send me some tunes or datalogs or whatever.... So I can peek up her skirt, so to speak. lol
Tony1968
2,313
5,099
NW Indiana
Understood. However being in 2nd at 1.48 to 1, isn't the rwhp/rwtq going to be off? By a lot? Being that gears are torque multipliers and all.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
In theory it would look like this "diesel Volkswagen" dyno result... ;) ;) ;)
With massive torque that was higher than HP, like skewed by like 100hp.... Allegedly....
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
We did some wheel speed calibration to match the rpms of the tires to the dyno itself
5,659
12,059
If you can get it to hook, then you’ll know what it’s doing imo.
Well cooked tires, half *ss prepped track, 16 psi in the Mickeys and 8 degrees on the hit is what it took for me. At 10 degrees I couldn’t get traction.
Refresh my memory, 275/60R15’s on the rear?
Tony is correct. 2nd gear pulls will joy give the same result as 1:1 in 3rd gear.
Good luck Chris - hope to see some results!!!!!!
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
275/50-15s in the back
