I'm doing the same thing this week with 3.23 gears from Motive that I got off Amazon for $124 in july. Seems they are $200 now. Waiting on a 2-jaw puller for the carrier bearings; I learned last night that the bearing splitter isn't going to work.sorry my bad i didn't say i will be using new bearings and new gears in a used carrier ..i couldn;t find thick 323 gears i don;t think anyone makes them should i use a spacer or pick another gear ratio .. are motive gears any good ?
I’ve never been able to get them with out either a bearing separator or a torch. They suck to remove.Late last summer I pickled the outside with phosphoric acid, wire brushed and pressure washed then sprayed whatever flat black I had. I used a can of brake clean and half a dozen rags to clean inside. Used some alcohol also. Getting these races off the carrier took me 3 hours. The Amazon puller was worthless (hooks galled); the harbor freight 2 arm puller was hard to keep centered and only when I cut the cages off and torched the race did they eventually give way. Father-in-law gave an extra set of hands.
I believe you're becoming the new "differential guy" and you'll soon be setting them up for drag racing.Got it together and listed on the marketplace for $600 today... If it doesn't sell I'll keep it as a spare. Maybe I'll put it in the Cutlass when I put in the 2004r.
