I have a factory master cylinder which I believe the front brake line out is 9/16 -18 1/4 inverted flare? I need to adapt that to 3/16 inch line 3/8-24 inverted flare so it will connect to my aftermarket prop valve. Having trouble finding the part I need. Any suggestions? I could use an adapter on the master if they make that particular one or I could run 1/4 inch line from the master to the prop valve and adapt that 1/4 line down to 3/16 there. Suggestions? thx
