You can make anything fit in your car with the right know how and fabrication and how much $$$$ your willing to spend...That being said, not a direct fit and will not be worth your trouble............. 8)
If your going to junkyard pick an axle then get a 9in. That way the center of the axle is regular mild steel. You can weld two DOM sleeves straight to the housing for the upper mounts and then reuse or refab some lower brackets.
