14x6 Buick Rallye Wheel differences
kustomkyle
646
47
Does anyone know what the differences are between the Buick rallye wheel, depending on the year range of manufacture?
Apparently 1978-1987 was part# 25504291, and there should be no question of fit on a G-Body.
But what about earlier wheels? 1971-1972 was part# 1236969, 1973-1977 was another part#, but I wouldn't see why these wouldn't be earlier versions of the same wheel, just revised/new part#'s along the way.
Any confirmation on this is greatly appreciated.
pagrunt
9,162
15,340
Elderton, Pa
One of the thing to look out for for most pre '75 (should be the year all GM cars had front discs standard) is that earlier wheels could be for either front drums or front discs. Other things that would be considered is design change/update, being chrome or painted.
kustomkyle
646
47
Right. That's the obvious guesstimate. It's safe to say 1971+ SHOULD fit disc or drum brakes. But before that? And on top of that, would the backspacing/dish be different between the various part #s and year ranges? The 15x7 wheels varied greatly. Visually all the 14x6 rallyes I've seen looked the same, but?
Not sure the chrome vs painted had different casting numbers. Part # should be different, but who knows about that either? I'm only aware of 1973+ being available painted, not chrome, but again could be mistaken.
I have chrome rallyes that were on a Nova of some sort before I got them, and found the other day that they are the 1978-1988 version by the casting code. Some have gotten crusty, and I'm trying to locate decent original ones.
kustomkyle
646
47
I'm going to say 4" BS on the older wheels, and 3.75 on newer...
Sounds like that would certainly be possible.
Aftermarket reproduction wheels are out there, but they only really work if your car is garage kept and never driven in wet weather. And even then, they'll get little green pits/corrosion nibs from condensation. $250/wheel for that? No.
Tuffregal83
639
1,150
Lockport, Il
There is a difference from regular 15 inch rallye to GSX 15 inch Buick rallye too. Something about setting a quarter one the first lip of the outside of the wheel that's the correct wheel for a 70-73 GSX or it might be 70 only can t remember
kustomkyle
646
47
Yes, I believe that pertains to the 1970 GS and GSX, the original Buick vs aftermarket reproduction wheels. I recall a photograph in an older issue of "Hemmings Muscle Machines" with the quarter sitting on the lip.
The reproduction is more generic I would assume so it can be used on a wider range of cars.
mcdriver
15
10
oklahoma city
which wheels might these be i know its not a GREAT pic ill upload another if need be
a great gbody man can tell from this view tho
Tuffregal83
639
1,150
Lockport, Il
Chevy wheel they put on G-bodys to S10s
