15x8 Weld Draglites with 275/60/15 for '80 Malibu- 3.5 or 4.5" backspacing????
Michael Bennett
121
41
Hi Guys,
Wanting to run 15x8 weld draglites with 275/60/15's on my 80 Malibu.
I currently have 275/60/15 Cooper Cobras on stock Monte SS wheels with 3.75 backspacing and clearance is tight on both ends.
Who's running the Weld Draglites and 275's on a Malibu and what backspacing are you using?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I don't understand the question, with a 3.75 BS you say the clearance is close on both sides and you want to run the same tire so why do you think 3.5 or 4.5 will work.... :unsure:
michmalibuman
1,040
1,154
I run a 275 60x15 on 15x8 corvette rally and I think its a 4" back space works fine.
Michael Bennett
121
41
Because I'm going from a 7 inch wide rim to an 8 inch. And because the Welds only come in 3.5 and 4.5 backspace so I'm stuck picking one of those options.
Michael Bennett
121
41
I should have mentioned that I am running a stock width 442 8.5" rear.
