16" zq8 rims vs 15" aluminum rims
Drkuhar
512
912
Girard, IL
I have a chance to pick up some s10 zq8 16" rims and tires for a good price. I ve seen pics of them in the postings here and they look sharp but I need to know if the will clear without needing spacers. my existing aluminum rims came off an s10 and are aftermarket 15 x 8 but must not have much back spacing (barely past rear brake drum).
Is there any downsides to going up to a 16 vs staying at 15" rims
Thanks
Drkuhar
512
912
Girard, IL
My 15" rims need all 4 tires they are not safe the 16" come with new tires. Owner has not replied back to me with the size
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
I'd grab the ZQ8's at that price. You may have to clearance, or ream out the center holes to fit over stock hubs. If you're using Blazer brakes (and hubs)....no problem.
As far as needing spacers, someone who already has a set on their car will have to elaborate.
Of course, you'll need a set of lugnuts with the proper shoulder.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Yes the wheels will fit without any spacers
1evilregal
3,056
4,357
Greensboro, NC
you may have to skim just a fine amount from the inside of the center hub.... mine will almost go on, and texas82gp has also confirmed this on his... only need what seems to be a paper's thickness taken off....
Drkuhar
512
912
Girard, IL
I'm still waiting on the seller to get back with me for a time to come check them out. I just didn't want to buy them and they rub and need spacers and longer studs. I'm all factory brakes front and rear so they should clear.
Thanks
Drkuhar
512
912
Girard, IL
Dont matter now. Dude couldn't answer me or wait for me to get out of school and sold them on me after we had already made arrangements
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Keep looking. With a tiny amount of filing to remove a small lip in the hub diameter, they fit just fine, no rubbing with up to a 255-50-16, all four corners.
