Have an estate barn find '79 Revcon motorhome which had been parked for ~10 years. I was told the 454 had been rebuilt 20K miles back. The Quadrajet has a reman sticker. I was able to drive it home (approximately 90 miles) with no major problems other than obvious carb issues, which I think are accelerator pump related. Backfiring, stumbling, etc. It idled fine, problems when accelerating, having to play with the throttle to keep it from dying or backfiring.
It has been a long time since I've played with a carb. While removing the carb, discovered the choke heat tube wasn't connected and the hole designed for the end was filled with rust & crud. Does the heat tube need to actually enter the hole to work effectively?
Disassembled the carb & on the underneath side of the main body encountered a gooey rubber like substance covering a whitish-yellow epoxy? Anyone have an idea as to what the rubber? stuff was? In removing the gooey mess also had some of the epoxy come away. Should I remove all of the epoxy & reapply some other brand (is there a preferred brand) in order to cover the area? Since this RV carb could be 15-20+ years old, should I remove all the old epoxy and re-apply more?
I've read several forums & can't find answers to these questions. Any help would be appreciated.
