Hey all. So, story time. There I was, making my way to McDonald's for a midnight McMuffin run, when my car, affectionately named "ThunderTurd" starts sputtering and spittin somethin horrible. Next thing I know, engine is still running, but power brakes go out. The car itself has power brakes, front disc rear drum, I have full fluid in the master cylinder, but it's like they aren't even there and the pedal is SUPER hard to push while this is happening. I coast it off to a side road, and for the life of me I can't get it started. Keep in mind this has a rigged up toggle-ish type ignition under the dash and I am by myself in front of said McDonalds. And when I do get it to fire, I HAVE to keep my foot (or in this case my hand as I am lying on the floor) on it at about 1000rpm or it will sputter and die. I looked in the carb (car is off at this point) and I can see the throat of the carb is pitch black, but the blades are still shiny and clean. Comes off when rubbed with finger and I can see the vapor from the cold gas on warm carb coming out of the front two barrels. And this car has had a history with running rough and not idleing worth a damn if it's below 30F here. It's 20F as of coasting the 4500lb boat home. It sits in the driveway until tomorrow. So, I'm thinking a GOOD carb rebuild is in order at the very least. It was running fine earlier today btw. Like a top. So, after this long post, what say you guys? I know it's a Ford, but the principles for carb operation should be the same, no?
