1978 Grand Prix Quick Ratio Steering Box Upgrade
Shelbywh89
42
16
8
Hello, I have a few questions about upgrading my Steering Box to a quick ratio one.
I've bought the NAPA 88-277101 or PS 391080 Steering Box.
Other then That I know I need a 800 Series Pitman arm.
Looking at the Allstar ALL56354
Other then that I'm looking for a hose kit since i've read the lines wont work something like the Summit Racing SUM-G3160
I'd appreciate any help and info for this swap for a 1978
oldsmobile joe
2,067
3,053
mpls
what motor do you have?
does this gear use oring or flare fittings?
for a return line, use edelmann fitting 39107 with sunsong hose 3501105
for pres hose, take whatever motor you have and find the hose for that motor when used in a 1981 gbody.
  • Friendly
timo22
550
1,072
St. Louis,Mo
I take it your existing lines are flare fittings and the new box is the o-ring type. I've switched over quite a few of steering boxes and always prefer to use factory parts.
If you have access to a junkyard, look for I believe 82 and up fbody,GBody or Bbody. Make sure it has the o-ring fittings and take the return line side off the steering box. The return side is low pressure so you can just use hose clamps. Remove the high pressure line from the back of the power steering pump. Once you have the line removed, unscrew the fitting from the back of the pump. I usually also take the spring and valve .
Now just remove your flare fitting off your existing pump and put the new one in. Then it's off to the parts store for a high pressure line and some power steering hose for the return side. timo22
Shelbywh89
42
16
8
Engine is 350...do have access to a junkyard but thought I’d just buy some new lines from summit
Ribbedroof
4,891
6,943
Wellston, OK
Believe the change to O ring fitting on the box was 1980, flare fitting for 78/79
Shelbywh89
42
16
8
OK I think I found everything I need to hook it up. Help me if i'm wrong
Gonna
Russell Performance 648060 and Russell Performance 648080 from the steering box to -6 AN line...To my power steering and use a Russell Performance 640380. that way I can run -6AN stainless line everything nice and neat
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Gonna
that is what I use and made my own high pressure SS line. I have headers so after the adapter in the ps pump I need a 90° fitting
Shelbywh89
42
16
8
Awesome glad I'm on the right track and getting the right stuff.... Do you happen to know if Allstar Performance ALL56357 is the right pitman arm needed
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
It appears by the application for that arm on Summit that is the correct arm. If you are going to make you own SS high pressure line I use this method with a zip tie and dremel tool to make the cut.
