1978 malibu spindle a 1 year only?
Rapidride2
35
30
I swore I read somewhere that the 1978 Malibu was a 1 year only spindle that is separate from the 79-up. Is this true?
I need to purchase a stock driver side spindle for my 78 malibu as the one on the car has stripped caliper mounting bolt holes.
I just wanna know what will or won't work. Thanks to all who reply.
pagrunt
9,122
15,255
Elderton, Pa
Yea, the spindle/bearings/rotor are one year only for '78. '79 up are the same regardless of inch stud ('79-'81) or metric stud ('82 up) rotors. The calipers will work on all years
Rapidride2
35
30
Thank you! I will be hunting for a 78' specific spindle.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the only difference is the 78 had the small outer bearing and maybe the studs are sae. For the stripped threads you could use a helicoil to fix it, it's sort of a common problem. In this video he needed to turn the helicoil in another 1/4 turn and break off the tang at the end of the helicoil
Ribbedroof
4,861
6,887
Wellston, OK
Second the helicoil
timo22
550
1,072
St. Louis,Mo
I think I would just put the 79 and later spindles on it and be done with it. Finding a 78 spindle will really narrow your search. You could pull the whole assembly off any 79 and up gbody..
timo22
Jim Larkin
23
I have a 78' monte, and am scrapping both my spindles. One side is a 78', one side is a 79'. I can check but if my memory is correct I have a 78' on my drivers side. Where are you located? Not looking for cash. Both side have almost new rotors, seals, pads, calipers and rotors (maybe 500 miles on all). Heavy to ship but if anywhere Pa there yours for the taking. I going the dual piston s-10 set up.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
It's an easy job to put in a helicoil and the tools would be cheaper than the shipping costs.
1bad79
1,023
890
Allendale mi
Where are you located? I have a pair from my 79 cutlass
