This car is a fresh build. Drive it from my house to the track and run mid 11's on motor (maybe low 11's with good air, lower gearing and a trans brake) and drive it home all without even popping the hood. It has THREE passes on it. Full cage with gauges and harnesses. 9" spooled rear. TH350 trans. 408ci engine with gear drive and Edelbrock aluminum heads. Aeromotive fuel regulator, MSD 7AL-2 and MSD adjustable timing control. This car starts runs idles perfectly. I love this car because it's so solid. I drove it to work in the summer and it did fine. The passes were done at Capital Raceway with a track temp of 136 degrees. Never had to pop the hood. I'm sure it'll go mid to low tens on nitrous. Perfect car to take to the track for hassle free fun. Great solid car. Hate to see it go but I'm moving and need to lighten the load. Located in Triangle, Va.
FOR FASTEST RESPONSE TEXT TWO ZERO TWO 400 ONE ZERO 13
- Show all
