1979 El Camino Front Coilovers
Vev78
n00b
Dec 9, 2021
2
Hello, I have a 79 El Camino that was lowered by putting very old tired springs in it. I love the stance but am having issues with rubbing. I am thinking of going with adjustable coil overs that will give me a better ride and allow for height adjustment.
Does anyone have experience with coilovers for a similar application? I am hoping to keep stock A arms as this is just a daily driver. Running a 350 w/aluminum heads.
I apreciate any help.
Supa.Slo.SS
Aug 7, 2020
57
26
CA
No experience with coil overs but from my research over the years everyone recommends drop spindles which corrects the suspension geometry & improves handling.
From what I remember with drop spindles you can reuse stock length springs.
melloelky
4,157
9,553
mass
Does anyone have experience with coil overs for a similar application? I am hoping to keep stock A arms as this is just a daily driver. Running a 350 w/aluminum heads.
I appreciate any help.
there's more than one train of thought here-if you replace your current very old tired spring with a new stock version,it'll be higher than it is now because it's a new spring and not an old very tired one that gives it that low slung look.have you looked into the tires sizes themselves to see if that's what's making the rubbing??an over sized tire could be the culprit on a stock set up as well. yes the adjustable will allow you to set your ride height where you'd like it but it's not the cheapest option going.aside from popular belief drop spindles don't change the alignment,it raises the wheel into the wheel house giving you your lowered stance.@no time with dropped spindles do the control arms or the parts that make up your front end,end up in a different position.all that happens is that "pin" that your bearings spin on is raised on the knuckle.therefore no gain is to be had.it also moves your outer tie rod closer to the inside/bottom of the wheel.not an issue for every one but still..sure a vehicle that's lower to the ground "will" handle better due to it's lower center of gravity but it's not by leaps and bounds difference.the geometry in these cars are trash,for most people it doesn't matter.most are shooting for a look-they jam drop spindles on and go cruising.smiles per gallon.where you're looking to change out a set of worn springs i wouldn't run a spring any shorter than a one inch less than stock.it makes for an even less than pleasant ride.FYI this is all from my experience-your mileage may vary..
Vev78
n00b
Dec 9, 2021
2
Vev78
n00b
Dec 9, 2021
2
This is the current stance. I like the height but would like to raise the frony end a bit. Not too concerned with investing money for a better ride and height adjustment. Leaning towards coil overs just have not researched what brand and weight range to buy.
I plan on dropping in an Erod LS3 to make this California Smog legal. Currently has a great running 350. Still trying to decide on a color for paint as well.
I appreciate the feedback.
elcotrk
Oct 8, 2021
51
9
8
I thought of upgrading to Coilovers got reply’s here, seen options on EBay most require A arms saw a couple said. You can use stock OEM A-arms they had smaller diameter springs cost more, forum reply said didn’t work out. Be sure to check with seller on installation and application and return /refund
I decided on Bilstein b6 front shocks. it’ seems like a big project could get complicated for the future maybe
