1980 cutlass street cruiser
Deadeyejedi80
133
144
Saratoga springs ny
thought i would get this thread started since things are starting to come together.i picked up the 1980 cutlass supreme i was looking at a while back and am currently building a 455 to drop in place of the 307 .the motor is a 76 455 block bored .030 over, squared ,0 decked, crank turned .020 ,and polished .speed pro 18cc dished pistons.im working on getting a set of e-heads redone with new valves ,guides springs and rockers from mondello as well as the cam .should be putting this thing together in a couple weeks.
Reactions: 6 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Are you sure it is a 76??? Looks like it has points.
Deadeyejedi80
133
144
Saratoga springs ny
Well it does have points and it was out of a 1974 toronado but I ran the numbers on the block and it checks out as 1976 , so it must have been swapped at some point .
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
2 things of note: Check your piston to bore clearance with the Speed Pro pistons- needs to be .003-.004 Bernard Mondello Performance in Corona, CA is the Mondello you want unless you like things shoved where the sun doesn't shine because that's what you'll get out of Paso Robles. I would also recommend Mark Remmel in FL (cutlassefi here) or BTR Performance in Rochester, NY for cam selection.
  • Informative
Reactions: 4 users
Oct 14, 2008
8,819
7,766
Melville,Saskatchewan
×2. I have one of Mark's cam in my Olds 350.
Deadeyejedi80
133
144
Saratoga springs ny
Thanks for the advice , it is Bernard mondello he’s figuring out my cam and head stuff . I have threads over on classic olds regarding this build , figured I come here for some of the GBody specific advice when It comes time to do the swap . I have heard of both the other guys you mentioned and they are well respected in the olds community as well
Deadeyejedi80
133
144
Saratoga springs ny
been a while since ive been here thought i would update this thread. making good progress on the 455 going to try to fire it up and break it in on the test stand soon
Reactions: 5 users
Deadeyejedi80
133
144
Saratoga springs ny
more pics
Reactions: 7 users
Deadeyejedi80
133
144
Saratoga springs ny
thanks shouldn't be much longer before its ready .looks like were going to get walloped with a snowstorm here in the northeast so lots of garage time in the future
