1980 Pontiac LeMans Station Wagon - Destined for Drag Week 2019
motorheadmike
motorheadmike
2,693
2,758
Ottawa, Ontario Canada
Picked up a couple of things. Including one plastic ball for that worn checkball bucket.
20180504_165623-jpg.88039
Also, I saved you from a full blown crotch shot... but, it did cross my mind to throw another package into the picture. Count yourselves lucky.
motorheadmike
motorheadmike
2,693
2,758
Tatiana and I finished up the shift kit installation today.
So per TransGo instructions you could go nuts and drill the separator plate to .125" (also known as the Sloppy Mechanics solution) - but, then your ability to tune it goes away; and that is where most people have to live with their choices when it comes to choosing shift firmness. Me? I am just going to tweak the tune to suit. That being said here are the hole sizes I used.
A (4) = .093"
B (3) = .110"
C (2) = .100"
Others options I have seen are A/B/C: .093"/.093"/.086" , .093/.105"/.125" (per my Jake's kit), and .098"/.110"/.081"
I used the BLUE inner accumulator spring for "even firmer" shifts.
Drilled a hole in the Chinesium dipstick to mark the pan rail, and put a SHCH through the unused bellhousing hole to mount the tube.
20180505_210353-jpg.88097
20180505_215626-jpg.88098
I should add that installing the TCC regulator valve was a horrible experience.
motorheadmike
motorheadmike
2,693
2,758
For future consideration.
20180507_164035-jpg.88175
TURNA
TURNA
4,635
2,688
Socialist NY
Pressure port?
Texas82GP
Texas82GP
4,346
3,514
Spring, Texas
motorheadmike
motorheadmike
2,693
2,758
My guess was for transmission temperature sender, remotely mounted for tunnel clearance.
Good guess, but no. Actually, it is a remote line pressure access point so that I can hook up a pressure transducer and datalog the line pressure... and tune the transmission accordingly. It is moved to that location for two reasons:
1. The signal will be buffered by a longer column of fluid, and less sensitive to minor pulsations and the like; and
2. Ease of access. Getting wrenches up on the side of the case is a bitch once this is all installed.
Reminds me... I need to add a breakout harness to the main harness for power, ground, and signal to/from the transducer.
motorheadmike
motorheadmike
2,693
2,758
Filled the converter with fluid and ordered another 250psi pressure transducer (link for the Canuckistanian DIY tunas: http://canada.newark.com/webapp/wcs...estType=Base&partNumber=99W2079&storeId=10196) because it was on sale ($88 CDN) and is way cheaper than a gauge.
Hopefully I will find some time this long weekend to button this thing up. I just need to find a case of AMSOIL ATF...
EDIT: Screw it, I don't have time to shop around. Paid their 6 month preferred sucker membership fee and had a case shipped to the house.
motorheadmike
motorheadmike
2,693
2,758
Well I wired it up for the 80E conversion tonight... only had to drink a pot of coffee to find the motivation to do wiring. This included the harness for the pressure transducer. I am running out of excuses not to have this thing done.
My in-laws are in town in mid-June so I want this back up and running by then to bring the noise for my girls and my nephew.
motorheadmike
motorheadmike
2,693
2,758
Transducer and the transmission fluid have arrived. Yesterday I hit the ol' Princess Auto an grabbed some pre-made 8' long -6AN hydraulic lines (maybe a little over kill) and some fittings, and then I razed the offcuts rack at the local metal supply store.
Hope to get some time to wrench this long weekend.
motorheadmike
motorheadmike
2,693
2,758
Weeeeeellllll... those 8 foot lines were way too long (6 feet would be better). So I made a pair of braided lines out of stuff I was saving for the Monte - oh well.
Note: There is an 8.5" difference between the front and rear cooler ports.
Thread starter Similar threads Forum Replies Date
CaliWagon83 Wagons! 1
CaliWagon83 Wagons! 25
Similar threads
