1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
This perpetual rainy weather is annoying if you like driving your car. But, it does give you time to work on projects.
Nothing quite says IDGAF like running a 3" hole saw through your core support, welding in a section of stainless exhaust pipe and gooping on some seam sealer to hide your sins.
Hopefully this helps keep the IATs in check - still have to finish the airbox/heatshield.
  • Winner
Reactions: 4 users
Clutch
5,189
10,913
Brick NJ
Mike it's such a nice car why did you make your seam sealer look like a child stick welder the pipe in? Come on your better than that lol
motorheadmike
8,976
27,522
Truthfully? Because it'll never be seen, and if doing it 80% gets me back in to see my kids I can live with the warts.
I know I won't regret not spending the added time on it, but I would regret not spending more time with my family.
Make sense?
  • Winner
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Looks more factory sloppy!!
motorheadmike
8,976
27,522
Turbo Zach
2,534
5,874
Make sense?
I know all too well what that is about! Something I would take all day making, I get a hour to do it now.
motorheadmike
8,976
27,522
I worked feverously between nap time and pre-dinner to finish laying down the fiberglass mat on the airbox/heatshield - at about an hour and a half a pop - to keep things moving on that abomination. The girls do like their Daddy on goofballs... even if he smells funny. Resin FTW!
Clutch
5,189
10,913
Brick NJ
View attachment 93117 View attachment 93118
Hooo that looks like a nightmare. Not your work I just hate working with fiberglass. Everytime glass work comes in the shop I try to pawn it off on somebody else and I always get stuck with it
motorheadmike
8,976
27,522
I was looking for this thread and I saw this: Get more exposure for your thread by making it sticky.
Between the seam sealer and the resin I think we are sticky enough up in here right now - thank you very much.
Ladies and gents I present to you the latest challenge with this thing: It drops into Open Loop at highway speeds (anything over about 63mph and 2300 rpm, and about 5% throttle) causes it to go from CL - Normal to OL - Accel/Decel which in turn causes it to go rich because the fuel trims turn off like if I was "givin' 'er!".
The only like instance I can find without a solution: https://forum.hptuners.com/showthread.php?42713-SD-Open-loop-tuning-Rich-at-part-throttle
It did not have this issue last Fall. Grrr...
Seems the OS (https://forum.hptuners.com/showthread.php?13185-What-exactly-is-included-w-1-BAR-MAF-RTT) I am using is essentially the stock OS with Real Time Tuning added (which I hardly ever use) so I may just take the stock tune, do a segment swap for the 4L80E, and then copy over the tune as is to see if that resolves it.
Alternatively I can turn on the STFT for OL and it should compensate up to 25% rich/lean. And people wonder why tuning is so expensive and specialized?
Grrr...
motorheadmike
8,976
27,522
So today I grabbed another MAP sensor and moved to the intake; we'll see if it helps with the stored codes.
Next up was the mission to further lower the IATs by sealing up the left side of the rad with some insulation; then I slapped the airbox on for visual giggles. I still need to trim it down, prime and paint it; then cover it with "hot boi" reflective tape, install the weatherstripping, and add the silicone duct hose - but all of that is coming on the slow boat from China.
Reactions: 4 users
