1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
O. D. Showtime
3,007
3,527
Regina Sask. Canada
Thanks Michael...always happy to help when I can.
Reactions: 10 users
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Started work on this:
Figure I should get this mocked up before I pull the bumper off to fit the fillers. Plus there is going to be some consideration/fabrication needed once I get in there. Lots of fore/aft and vertical adjustment.
The hitch mount comes of for other prospective attachments (parachute?).
Should test it on the Monte too.
Reactions: 8 users
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
What do you plan to tow with that setup?
Got your money's worth out of the can of Mopar cleaner.
motorheadmike
8,976
27,522
Nothing really. I just wanted something to hang my hitch basket on for Drag Week or road trips. The bar should double as a stiffening brace.
As for that can of brake cleaner... I like to test my grip strength while huffing solvents.
Reactions: 6 users
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Dual vices are an interesting touch. Are they mounted on plates so that they are removable?
motorheadmike
8,976
27,522
I suppose I could. But, those two have been mounted on the bench, in those locations, for almost a decade. One is the primary and the other (with the swivel) is often used as my third hand. They are aligned so that I can steady/hold/support a long piece of material. Those plates are bolted to the bench through the vices to keep them from shifting - they are very heavy.
Reactions: 6 users
melloelky
4,157
9,553
mass
at first i thought you were making a trans cross member (think ice man style) then i saw the hitch in the middle and thought it was some kinda awful trans torque arm/spare parts scavenger hunt but was then distracted by the crushed aerosol can...
motorheadmike
8,976
27,522
Got this sent to me this morning by a fellow G-Body/Hellcat owner:
Here's to hoping we can all get out and play soon.
  • Love
  • Winner
Reactions: 10 users
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
Damn, that wagon sounds good!
motorheadmike
8,976
27,522
