1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
Lookin good under that hood!!!!
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Changed out the complex spring set up for a set of single springs from the front of a 98-02 LS1 F-body. 292lbs/in linear rate. Had to chop 3 full coils off to fit the Speedway hats and get the car down to 27.5". A bit higher than before but the car is getting a hitch installed soon and who knows what that is going to weigh...
Clutch
5,183
10,900
Brick NJ
My hitch is off I'll weigh it for you
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
What anti roll bar is that?
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Thanks. Do you remember what it cost? No prices on there site.
motorheadmike
8,976
27,522
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Awesome thanks!
motorheadmike
8,976
27,522
I imagine there are a few folks questioning the choice of such a high rate rear spring, and then proceeding to cut it. The latter definitely raises some valid points when you look at the math: https://www.eatondetroitspring.com/cutting-coil-springs-calculations/
The thing that must be kept it mind, and was a massive oversight on my part when I altered my plan, is how much heavier the Dana 60 differential and tire/wheel combo is compared to stockish stuff. That is a lot of inertia to manage.
Combined with a hollow swaybar I may not have over sprung the rear; especially once I move up to some MOOG 5664s (probably going to get chopped too) from the 5660s currently in the front. Again, a similiar issue exists up front with the weight of the tire/wheel choice.
The grim reality is this car ended up a lot heavier than I initially envisioned.
