1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
And that is pretty much it - the engine is built; except that I have to measure for and order some pushrods. The last thing I had to finish up was the nitrous kit. The goal here was to install all of the components on the intake itself (short of a few relays); just in case I need to remove it from the engine (to say install it into the car).
Unfortunately the old dishwasher I salvaged the micro-switch from didn't have a lever arm installed... so I made one and integrated it into the bracket. The WOT micro-switch is connected to a fuel pressure safety switch, which is connected to an RPM window switch - because safety first.
I would really like to set the purge up to bleed out of the unused antenna hole in the fender.
motorheadmike
8,976
27,522
Tore into the trans (out of 2002 Tahoe - go figure) and started to install some parts from Sonnax:
Performance Pack (HP-4l60E-01)
2nd and 4th Gear Super Servos (779911-03K and 77767)
2-3 Shift Valve (77754-41)
The instructions are pretty straight forward, but still leave a little bit to be desire from a clarity stand point if you have never done this before. The most I have ever done with a transmission to this point was install them, swap a converter, and change out a servo. So this was new territory for me. To help anyone along here are a bunch of photos to augment the instructions.
I disabled the PWM function of the TCC, so now it should work just like an ON/OFF switch (like an old school TCC trans).
Plus, there is a Coan 3200 stall, single disc, converter waiting to go on.
motorheadmike
8,976
27,522
Few more.
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,691
Spring, Texas
You might want to consider putting in the Sonnax input shaft/drum assembly. My 5.3 with bolt ons was pulling the input shaft out of the stock drum. The Sonnax piece is expensive but nearly bulletproof. A common 4l60/65/70 failure is to blow the snap ring out of the input drum that secures the clutch pack. The Sonnax drum has a bolt on cover.
I also recommend the beast sun shell.
  • Informative
motorheadmike
8,976
27,522
I appreciate the advice! I am well aware of the problem areas (http://www.tbssowners.com/forums/4l70e-transmission-help/209153-blew-up-my-rpm-level-5-today.html) and potential solutions of the 4L60E family of transmissions, however I am only doing the minimum to keep this trans alive for awhile with the added power. There is no way I am investing that kind of time and money into a failure prone platform - especially in a used transmission. When this fails, and it will, I am going to put either a 4L80E or TH400/GV unit in its place.
That being said this transmission took a pretty healthy beating (drags, auto-x, shameless burnouts) from us from 2007 to 2013 before Natasha's Camaro was parked (and later parted out).
That and if I keep adding things to this project it will never be finished, and I really want to crawl back out of rabbit hole I fell down...
motorheadmike
8,976
27,522
Spent most of the day shoveling heavy wet snow.
But, I did manage to get the transmission pan stripped and painted. Somewhere down the line a goon threw black paint on the pan and it was flaking off at the slightest touch. I scuffed it up, grabbed some primer and some gunmetal wheel paint; but, man is it still ugly.
And I finally put on my man-pants and cut the exhaust tips. A long sawzall blade and slight touch-up with a hand-file later, and I could breathe a sigh of relief. Done. Once the engine and trans goes in I can start laying out the whole system - for some reason I love building/fitting exhaust systems.
You know you have a good wife when she runs to the transmission parts to store to pick up your order. But, then mentions how "two gaskets" and a "little thing" don't look like they are "worth $70". She's a keeper.
motorheadmike
8,976
27,522
Not a lot was accomplished but, a BIG box in the project was ticked:
The trans was buttoned up today with the Sonnax 2-3 Shift valve being the last piece. I used the Sonnax "plastic" balls in all of the case and VB locations. I saturated the filter element with some fluid to avoid a dry start up (do the same thing with an oil change). Hopefully this thing works well for a while. Just have to top it off with some Amsoil ATL.
For reference the details on the internal tweaking of the 4L60E is documented here: http://ls1tech.com/forums/automatic-transmission/1856669-4l60e-shift-kit-advice-needed.html
motorheadmike
8,976
27,522
Speaking of jobs that require manning up, and a lot of manpower: Today I rolled the rear inner fender lips. Which is much preferred method to chopping them out to avoid cutting side walls. It also preserves the stock spot welds, and strength and integrity of the sheet metal.
It will tuck (squeeze) the 345s now.
I also mocked up the 17x11s to suit. Added a 1/8" spacer behind them to see how far out I can safely bring the wheels and still have full engagement on the studs/lugs. There is 1.5" minimum clear around the rim on the inside - and by my calculations for mounted section width I only need 1.25" to the inside and outside.
Next up: paint the hoops and mount the buns.
