I just came from the pick-your-part, and there were 1980 Cutlass Supreme RH & LH door glass. Will this glass fit my 1978 Cutlass Salon?
A47 is the notchback coupes, Cutlass Supreme and Cutlass Calais only. The Cutlass Salon coupe was G87 (Cutlass Salon Brougham was J87). I don't think they are interchangeable. If you go on car-part.com and search for 1978 Cutlass front door glass they ask specifically if the car is a notchback or a fastback style and they give you different salvage yard listings. The best thing to do would be to inquire at a glass shop and see if they are the same number.Parts book says 78-80 A47 will interchange. P/N 20152414 (RH) and 20152415 (LH) for tinted side window glass.
Ok, I fumbled. Too used to looking at 47 body styles. Still, I think it holds true that 78-80 still interchanges by year as long as it's an Olds and same body style.A47 is the notchback coupes, Cutlass Supreme and Cutlass Calais only. The Cutlass Salon coupe was G87 (Cutlass Salon Brougham was J87). I don't think they are interchangeable. If you go on car-part.com and search for 1978 Cutlass front door glass they ask specifically if the car is a notchback or a fastback style and they give you different salvage yard listings. The best thing to do would be to inquire at a glass shop and see if they are the same number.
