1982 Monte E85 Blow Thru Procharged SBC Build *PICS and VIDS ADDED***RUNNING***
wingnutks
420
1,314
Very nice. What do have for stopping power.
Manual brakes. Stock fronts with drilled and slotted rotors. Rears are big ford drums.
wingnutks
420
1,314
Got the intake piping cut and fitted and installed BOV, also thru oil in the blower. My alt and crank pulley lined up well, but my water pump was about 1/10-1/8 inch too far inward. I grabbed some Allstar water pump shims. I installed a .08" shim and it now lines up. Still have to re-install crank bolt, measure for an accessory belt, install supercharger belt, a couple vacuum lines, change plugs, and mount the fuel lines with some pillow clamps. I will load a base tune into the MSD before the first drive.
Reactions: 7 users
wingnutks
420
1,314
BTW forgot a pic of the car lol
  • Love
Reactions: 10 users
wingnutks
420
1,314
A couple random videos.
This one is just a random start up the first day, car was already warm and I was just dialing in the idle tune.
This video is after I got the idle tune down. This is a completely cold start. It was about 30 degrees out and the car had sat for 2 days. Not too bad for blow thru e85!
Reactions: 4 users
wingnutks
420
1,314
Here is the sump/pump set up. -10AN to the filter (stainless element) --> -10AN from filter to pump (AEM 400) --> -8AN from pump to regulator. From regulator back to the bung on the driver side of the tank I have a -10AN.
Reactions: 6 users
