Since I asked about putting the column wiper switch into a non-wiper column in another thread, I figure to check out the columns I have to figure this out myself. Did some looking inside the upper bowls of the columns I have in the garage to see if there was any physical differences to convert non-wiper switch columns to have the switch. From what I can see there is not any differences between the '86 one & the '81 one I'll be using. Even looked at my '78 one & the same. I even looked over the loose switch I have & it'll mount the same way as the lever only mount/switch activator (or what the proper name is for that part.) The only pain will be having to take the upper bowl apart to swap out the parts.
