1983 Oldsmobile Cutlass Supreme Sedan LS Turbo Build
81cutlass
4,649
13,565
Western MN
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Are you running the stock pickup pan?
I have been running a pickup pan on mine for 2 years, hangs low but if you dont drive like a fool its fine. I had my own mounts made.
This one is probably the only one that will fit your mounts short of spendin $400 on the holley pan.
https://www.poormanmotorsports.com/...x-aluminum-rear-sump-oil-pan-aluminum-natural
Stock truck oil pan, yes. It annoying to me that an damn oil pan costs $400. So I am trying to work around that. That pan looks good however.
I ran a slammed VW for years without any pan issues, so I know how to drive to avoid most problems.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Ordered this to make me feel better:
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Overshot the spacer so I will attempt round three tomorrow:
Will likely need 3 washers on bottom, 2 on top. Grade 8.8 bolts.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
One step closer:
It’s close, but truck pan fits:
B095A333-C5E2-4C07-9A12-E3834AAFCB2C.jpeg AA461180-37FB-4527-8322-C6B1808D0560.jpeg
I can definitely live with this:
Should be able fit some goodies up front:
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Removed AC condenser to clean up and undercoat:
Moved this beautiful b*st*rd into position:
Bolts to engine and figuring out how to reuse the stock crossmember:
Looks like I will be able to use the bracket I cut off on the other side of the crossmember.
