1983 Oldsmobile Cutlass Supreme Sedan LS Turbo Build
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
GroceryGetter83 would it have been possible to have the return feed a little higher?
I think any higher and it won't drain back from the turbo. Usually people drain to the pan, but I thought this would work.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
It will work, you just need a 90° instead of a straight....
uneek1976
653
129
Sugar Grove IL/ Chicago
Ok, because I was thinking about going that exact route you took. But since I haven't done my front cover yet, where in the pan would the fitting be put?
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
81cutlass
4,649
13,565
Western MN
Did you already tap that cover to pipe thread?
If you did you can get a -8 (or whatever size that is) to 3/8 NPT 90
OR, get a -8 to ORB (o ring boss) 90 which has straight cut threads and an o ring with a nut to adjust o ring squeeze. That allows you to put the fitting where ever you want and tighten the o ring. They are used in industrial hydraulics and are good to 2000+PSI so they are good here for return for sure.
Reactions: 5 users
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
The cover is tapped for 1/2" NPT. I will see if I can bend the 90* fitting I have to clear. I don't want to take the balancer off again if I don't have to. I will look into this fitting too. Thanks!
