1984 Hurst Olds Control Arms
chrise1984
n00b
Dec 10, 2020
2
I am working restoring my 84 Hurst Olds. I was planning on replacing the both upper and lower control arm assemblies rather than new bushings and repaint. andI am having trouble finding lower control arms. any recommendations? thanks
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Front or rear? S-10 arms fit the front, and are available from Dorman. Don't go all primadonna, and insist on G-body arms. You'll pay through the nose for NOS, or go aftermarket.
69hurstolds
8,185
17,569
Reactions: 5 users
69hurstolds
8,185
17,569
Isn't there something about the lower rear mounting hole needing hogged out or something to use them? I think there's something different about them. Gotta cover all the bases if you're not using GENUINE G-body arms. :)
Mac442
257
384
Ocean County, NJ
I did have to use some “persuasion” to get the rears of the lower arms in place in my frame...The Metal sleeves in the pressed in bushings seemed slight too large to fit in my frame...
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
Get a set of tubulars for the uppers. Southside Performance sells a decent set.
UNGN
3,048
3,264
Southlake, TX
If you want to make the car handle and steer better and lower the front end .75" with no other changes, replace the Lower ball joints with 1/2" taller proforged ones from summit.
They are only $15 more than a quality regular ball joint and you will see and feel the difference.
MrSony
6,826
6,731
Des Moines, Iowa
These?
UNGN
3,048
3,264
Southlake, TX
