Hello everyone. I’m hoping to find some help with a car I just bought and figured this would be the best place to look. I just bought a 1984 Monte Carlo VIN: 1G1AZ3798ER118759. I used to have an 84 when I was younger, so I’ve always wanted another. Anyway, this car I bought doesn’t have an engine or transmission. From the VIN, I can tell this is a base model and originally had a V6, but the guy I bought it from said that it had a V8 in it last. He supposedly hadn’t owned it for very long. There are motor mount brackets present on the cross member, along with dual exhaust (from the firewall back). Also in the rear floor board and trunk are two V8 exhaust manifolds, drive shaft, AC compressor, torque converter, radiator and power steering pump. All of the wiring under the hood appears to have been disconnected, not cut.
So, my predicament is that I don’t know how to tell if in fact a V8 was last installed in the car or not. I would like to have a V8, but if it’s already set up for a V6, it would be easier to purchase and install as such. I guess I’m wondering if anyone can tell me based off of the appearance and location of the engine mounts, and also any wiring present. I’m not ready for an extensive build right now, so I’m really just trying to get it running and moving for now, then work on it more as I have time.
Thanks a lot in advance!
