1984 Monte Carlo SS 6.0l & T56 Swap Build
Built6spdMCSS
5,804
9,714
Florida Beach
I did the initial build on this car in Dec 2010, and in the last couple weeks overhauled the car installing new parts and modifying others to make the build more refined.
This is what the car currently looks like, has come a long ways in 9 years since I bought it.
MOD LIST:
1984 Monte SS
2006 6.0l LQ4, LS2 243 Heads, LS6 Intake, LS1 Fbody Accessories
Thunder Racing Cam, 230/236 .592/.602 112+3 LSA, Texas Speed Hardened Pushrods, BTR .660 Dual Coil Valve Springs
Built T56 6spd Manual Transmission, Monster Stage 3 Clutch, B&M Ripper Shifter, custom Clutch Pedal
Pypes Race Pro Mufflers, 3" True Dual Exhaust over axle with Xpipe
Quick Performance Custom 9" Rear End, Detroit TruTrac Differential with Richmond 3.89 Gears
UMI Performance Front & Rear Solid Sway Bars, Rear Boxed Lower Control Arms with Double Adjustable Upper Control Arms
Bilstein Shocks, Eibach Front Springs cut, UMI Performance Rear Springs, C5 Z06 Front Disc Brakes, LT1 Fbody Rear Disc Brakes, TRZ Solid Body Bushings
Tuned with HP Tuners
MODS I USED TO MAKE THE LS SWAP:
EBAY LS NON SETBACK SBC Adapter Plates, 1999-2002 GM Truck Throttle Cable
Heddman Hustler 45036 LS Gbody Swap Long Tube Headers
Holley 302-1 Oil Pan (Yes, it fits this car)
LT1 Fbody Radiator & Fans, 1998 Fbody Fuse Box, modified 1999 LS1 Fbody Engine Harness, 2002 LS1 Fbody 0411 PCM
Modified Jegs 700R4 Double Hump Crossmember for the T56
EFI Gbody Gas Tank, Walbro 255 EFI Intank Pump, Modified EFI Gbody Sending Unit, C5 Corvette Fuel Filter/Regulator
T56 6spd Manual Gbody Swap
Electronic Speedo Conversion
C5 Z06 Front Brake Swap
Detailed pictures of the setup in my SS
  • Love
Reactions: 5 users
Built6spdMCSS
5,804
9,714
Florida Beach
With the recent overhaul I swapped in the Holley 302-1 Oil Pan for proper ground clearance. It is flush with the Engine Cradle.
I used to have the GM Muscle Car Oil Pan, also called the H3 Pan.
Pics below comparing the two..
I freshened up the T56, and installed the Monster Stage 3 Clutch to get a little more bite over the LS7 Clutch I had
Once that was done, the package was bolted together and ready for install. The Holley Pan is about 1/4" lower than the T56 Bellhousing
Mounts are the stock Gbody SBC Clamshells bolted onto LS NON SETBACK Plates and on the factory cradle pads
Fuel System has been the same for 9 years without issue. GM EFI Gbody Gas Tank, GM Gbody EFI Sending Unit modified to work with the LS Setup, Walbro 255 Pump.
Gas Tank I used
First thing I did was take the Sending Unit and adapted it for the LS Return setup. The way it was setup from the factory is the 1/4" was the return, and the 5/16" was the EVAP Vent. I turned the 1/4" into the vent, and the 5/16" into the return for the LS fuel system.
I modified the Sending Unit by cutting off the baffle on the end of the 5/16" line and opened up the end of it. This picture here is BEFORE I drilled out that little pin hole there. This little hole on the 5/16" line NEEDS TO BE DRILLED OUT.
Once that is done, then cut a vent in the 1/4 metal line to vent the tank. This helps, it still gets a little splash back on fill up but that is by the design of the whole system. Cutting this slit on the 1/4" now turns that into the vent for the gas tank.
Here is the finished setup with a Walbro 255 GSS 342 Pump installed. The threaded flange was also cut off of the 3/8" line on the sending unit
Install into the EFI Gas Tank and run the proper EFI Rubber Lines
C5 Filter/Regulator mounted up on the front passengers corner
EVAP Line on the SS used as the 5/16" return line
Built6spdMCSS
5,804
9,714
Florida Beach
GM LS1 Fbody Engine Accessories
GM LT1 Fbody Radiator & Fans
Jeep Cherokee Steering Shaft Mod
Using stock 1999-2002 Truck Throttle Cable
Modified 1999 LS1 Fbody Harness
2002 PCM mounted behind the dash, wiring ran through the Trans Tunnel
1998 Fbody Fuse Box mounted in the front drivers corner
Battery relocation to the trunk
T56 Shifter location
Reactions: 6 users
Built6spdMCSS
5,804
9,714
Florida Beach
Thanks. I had another thread but since I did the over haul and newer parts fit, I figured I would make this to help people see what works and if they have reading comprehension with skill they can build a car up
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Very nice!
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
You would be surprised. With all the swap parts and build threads out there and on here, people are still clueless. An LS should be able to throw itself into anything at this point.
  • Winner
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Especially into one of these!!!
:banana::banana::banana::banana::banana:
  • Angry
Reactions: 8 users
Built6spdMCSS
5,804
9,714
Florida Beach
I'm not surprised really... the facebook groups I admin we see it all the time. People are lazy. I even took the time to make a section of this mentioning what parts I used and I bet someone still will ask.
