CUTLASS 1984 olds cutlass supreme, 350 v8 engine
8,819
7,766
Is this a stock Olds 350? Anything with too much cam on a tight LSA will run shitty.
19,992
If you are not using the computer in the car anymore there is a wire harness under the heater/AC box.
Any wire that comes out of that harness can be cut and removed.
It is no longer needed and the removal will not effect anything
