1984 Oldsmobile Cutlass Supreme Brougham
gdouaire
626
439
Québec City, Québec CANADA
A polaroid seemed appropriate.
gdouaire
626
439
Turns out, even if you get all the specific bolt spacing/diameter specs right for the engine fan clutch, there's one parameter left, never clarified when you buy the clutch: the length of the water pump shaft w/r to the clutch shaft "hole". Well, that is fun. Luckily, my car came with a spare water pump (thanks dad!), and the water pump currently on my Cutlass is worn out (squeaks when turned by hand), so I trimmed the shaft on the new pump & will install it on the car 🙈🙉🙊
...and then the new fan clutch will fit.
gdouaire
626
439
I had a B&M lock-up control module for my new 200-4R, but was missing some of the wiring. So i created this sh*t so I can test it using the cigarette lighter.
gdouaire
626
439
It turns out, my TH-200-4R speedo gears are such a mismatch with the car's rear end, it will not even reach minimum speed to trigger the lock-up module :)
so, let's stash this until the 3.42 differential is installed.
gdouaire
626
439
Sooo... Removing the carpet revealed the rust... :) A few holes, nothing major, not pretty, but I have seen worst.
gdouaire
626
439
Would have loved to work on the floor, but right now, weather is very rainy around here.
So....
Worked on the seats instead. Converting the manual 45-55 seats into power seats, using Eldorado power seat rails. Was already partially done for the driver seat, now aligning everything.
I had to cut the side of the seats, but it turned out alright, using a metal plate hidden behind the seat hide. Looks almost OEM in my book, so OK
gdouaire
626
439
Done: thick coat of rust encapsulator.
Next up: fiberglass for the holes
