1984 REGAL LIMITED HORN SET
Steve84
140
35
Hi Everyone! I am back. Have another dilemma. After my factory 2-horn set crapped out on my Regal 2 years ago, my mechanic put in something to replace them. Now this set crapped out. Amazing how my original lasted over 30 years and the NEW set lasted only 2.
Anyway the horns are located under inner front drivers side fender under the hood. Which set do I need? I went onto GM website and they list all different ones like high note, low note, c note f note d note... etc. What the hell?
Anyone can help?
  • 12368063
    Horn
    HORN KIT, Horn
    high pitch
    Replaced by:84594588
    $73.68
    $32.13
  • 12368063
    HORN
    HORN KIT, Horn
    "A" Note
    $73.68
    $32.13
  • 12368063
    HORN
    HORN KIT, Horn
    "C" Note
    $73.68
    $32.13
  • 12368064
    Horn
    HORN KIT, Horn
    low note
    Replaced by:84594590
    $78.05
    $34.05
  • 12368064
    HORN
    HORN KIT, Horn
    "F" Note
    $78.05
    $34.05
  • 12368065
    HORN
    HORN, Horn
    "D" Note
ck80
Moderator
Moderator
5,742
9,114
Just looking at it I only see two part numbers grouping the respective pitches to higher and lower, that were later superceded by a different part number each.
My assumption would be one of each of the new part numbers.
Steve84
140
35
That makes sense. Now to find the KIT PART# that contains BOTH horns. Buying separately is way too expensive. Thanks !
Gonzo1970
898
1,302
ahooga horn ftw
Or... My personal Preference:
Good Ol Nathan P3's
-Gonz
Steve84
140
35
Does anyone know the KIT # for both high & low horns? Buying them separate is way expensive!
Gonzo1970
898
1,302
Sorry, I thought you got your answer before I so rudely interrupted.
-Gonz
Ribbedroof
4,862
6,888
Wellston, OK
I work in the collision industry, have never seen a kit for them, it's always each.
I put Crown Vic horns on mine....come as a pair on a bracket, and if you buy them at the salvage yard, you can cut the pigtail for them off the donor...and they're cheap. We fix a lot of police cars. so I don't have to buy them new, but I was buying CV washer reservoirs with pigtail, hose, and pump for $5 at local pull-a-part....can't imagine horns being much more
