1985 Cutlass SBC w/350TH trans. shifter cable bracket
rick48195
May 21, 2009
89
I have a 1985 Cutlass with a 350TH trans and stock floor shifter and would like to know what others have done for a shifter cable bracket, Every aftermarket bracket I have found does not fit, The bracket bolts onto the side of trans pan
custom442
1,889
4
Houston
You need the one that holds the cable to the trans?
I wonder if hurst or B&M will sell just that bracket for the th350, call them & check it out
Also it's just a cable so as long as it's held stationary with the correct length you can bolt it wherever with a clamp, underneath the floor pan, on the crossmember...
rick48195
May 21, 2009
89
Yes that was my first thought but, did GM ever make a G-body with a 350TH trans and floor shift like my 85 cutty floor shift, I don't think they did.
dan2286
2,233
4
Cleveland, Ohio
There is one in the junk yard by me right now.
